Read data from Sensor DAQ
I am trying to read co2 measurements from the Sensor DAQ. I am not sure how I can get LabVIEW to use the SDAQ. Is there a program that I need to download?
Chod
(3,192 Views)
Hi Chod,
Assuming you are using the Vernier SensorDAQ with the C02 Sensor, the following page has instructions for installation to LabVIEW:
Using SensorDAQ with LabVIEW
You will also need to have DAQmx Installed on your system.  This should have came on a CD with your SensorDAQ device, but if you need to download a copy of the driver you can do so here (be sure to choose a version compatibile with your OS and version of LabVIEW).
Best Regards,
John Passiak
(3,161 Views)
