Read data from USB-TC in a MyRIO project
I will really appreciate any help from this community
I am trying to deploy a control design on my system using myRIO and I need the temperature data to implement the control algorithm on my system. I have a USB-TC for reading temperature data from a thermocouple. I used the "Ulx to Labview" to set it up and the VI works well by itself. However, adding the VI to myRIO project breaks the VI.
A screenshot of the error is attached.
Please, can anyone let me know how to fix this?
(2,421 Views)
The download for ULx for NI LabVIEW lists the supported OS as Windows. It seems likely that at the bottom of the sub-VI's they provide that the end up calling a DLL which wouldn't be expected to work on a Linux system (most cRIO's run Linux).
Can you dig into the sub-VI's and see what is in there? Do you see any calls to DLL's?
(2,376 Views)
Accepted by topic author Gee22
Thank you for your response.
I figured it out. I had to use network shared variables to get the RT data from the ULx subVI.
(2,371 Views)
