Read data from serial port COM2 and log it
Hi there!
I have no experience dealing with Signalexpress
Im trying to read data from serial port COM2.
I would like to colect data and log it with signal express. Is it possible?
thanks
Signal Express 2011, WinXP, NI PCI 6221, Ni cDAQ 9174, Ni 9235
(2,721 Views)
Yes if the instrument you are using is an IVI instrument that it supports.
Connect to a Wide Variety of Hardware
Use LabVIEW SignalExpress with all National Instruments data acquisition (DAQ) hardware, more than 400 IVI benchtop instruments, and NI modular instruments.
Omar
(2,717 Views)
And in the future, you will want to post to the SignalExpress board instead of the LabVIEW one. LabVIEW is the programming language that was used to create the application called SignalExpress.
(2,706 Views)
