09-16-2010 12:09 AM
Hi Wilmer,
i have a question. Can you please explain why you use an embedded webpage, but you want to automatically login? I'm sure my posted example should work. It works for my. I only get error 66, but this is ok. Can you also explain what you aim behind all this is?
Try to help.
Mike
09-16-2010 08:47 AM
Hi MikeS81,
I have an electronic equipment, which I have to remotely monitor to capture certain data values and then processing them, equipment is located in a very remote and only has an Ethernet communications port, this equipment has a website Embedded, using Internet Explorer on my PC I can enter the site prior entry of the username and password, and see different data, I need to extract this data using Labview, it is possible to do this?
09-16-2010 09:26 AM
Hi Wilmer,
yes it's possible and you should be able to do it if you use my vi. If you have the correct username and password, then you should be able to get the result page. No need to use the activex Webbrowser.
Mike
09-16-2010 10:40 AM
MikeS81, If you want I could send you by mail, the username and password that you try it, maybe there's something I'm doing wrong, I can not post to this forum those data because it is private
09-16-2010 01:17 PM
Hi Wilmer,
you can send me a mail to this address.
007918097f20@910cc211f3e4.anonbox.net
It's valid til 09/17/10 11:59 p.m.
Mike
09-17-2010 12:41 AM
Hi Wilmer,
i made some changes on the vi and this works for me to get one of you pages.
Hope it helps
Mike
09-17-2010 08:54 AM
Hi MikeS81, Thank you very much for your help !!!, but I just did a test with the new VI (8.5) you have posted and the Base64 that I've created but I can not enter the website, I think the error is in the Base64 that I'm generating, if not too much to ask could you send me or publish the "Util convert to Base64.vi"?
Regards
Wilmer
