Read data sent via ethernet with TCP
OK, now that I see the camera model it looks like it's specifically a bar code camera.
Are you trying to get the full video, or just the bar code data?  If you only need the bar code results, I recommend you look into enabling the MODBUS option and using that.  There are at least 3 existing, free, MODBUS toolkits for LabVIEW.  (Ethernet/IP, the only other option I have made work, has 1 non-free toolkit and one free .NET library that I found).
If you want the raw video feed, you might be out of luck without investing a ton of time into trying to reverse engineer their protocols.
Message 11 of 12
(497 Views)
I just want the data, I'll look for the MODBUS way then, thanks ! I'm also trying to catch the data with a FTP server, it seems to be the simplest way according to the camera support guy I talked to. I will post an update here once I managed to do it.
Message 12 of 12
(481 Views)
