Read data with spreadsheet in different formats
Hi all,
I have to read these data table using the VI Read From Spreadsheet File of .dat file:
377.88 6.326826E+03 2.024894E+03 253.794
377.89 6.328341E+03 2.026409E+03 253.984
377.90 6.329855E+03 2.027923E+03 254.173
377.91 6.331370E+03 2.029438E+03 254.363
Note that we have two differents formats: float and scientific notation, then i tried with %#g for example, but i can' t read, only i read the first colum.
Could u help me plz?
César
(3,307 Views)
Can you post the part of your program that is reading this, either actual code (best) or an image (in .png or .jpg, NOT .bmp)
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,302 Views)
Not sure, but it may be the delimiters you are using in your file. Can you attach part of one of your data files? What are you using as a "delimiter" between the values? If you copy the text and paste in to a string control or indicator you can then right click on it and select "\" Codes Display to see what characters are used. Also the end of line character needs to be examined. The "Read from spreadsheet" expects carriage return, newline displayed as \r\n in the above way. It (the read from spreadsheet vi) does have a terminal that allows you to specify the EOL as well as the "delimiter". It expects tabs "\t" so if you have spaces "\s" it won't differentiate between groups on a line, which would give you only the first column.
Putnam
LabVIEW Champion
(3,297 Views)
I attached the frontal and block of VI, Well, a simple solution is resaved the file again, but I want to ensure that my program will work for any event: files (.dat , .txt ,csv).
In the imagen you can see the configuration of VI.
Bets
Cesar
(3,289 Views)
