Read datas from HTML or XML file in LabView
Hi all,
I need help in the following. I need to read the measurement results from test report into LabView. Test report format is HTML or XML. Please give me some advice on how to do this?
Thank you.
Mik
(7,813 Views)
You may read HTML report by Read from Text File vi. I am not sure about xml, but you may try.
Labview user
(7,803 Views)
A quick search through the forums will point you to this thread which has some excellent advice and a effecient parser vi
(7,796 Views)
