Read file .txt per line with timming
Hello guys, i'm new here and with labview.
I'd like to do a reader file with NMEA code and after open i'd like to read line per line or multiples lines (user control this step) until the end of file with a delay (user control this delay) and send it to a serial port.
Example
User set to read 2 lines/2000 ms
Line 1
Line 2
Send to serial port
Wait 2000 ms
Line 3
Line 4
Wait 2000 ms
Message 1 of 9
(4,224 Views)
Hi gorio,
and what's your problem?
What have you programmed so far?
Sounds like you plan to program a state machine...
Message 2 of 9
(4,219 Views)
I'm on my phone and i cant send an image to show my problem, but i can read file (all lines but not per lines with timming). Sorry my ignorance but ASAP i'll post my project here.
Message 3 of 9
(4,211 Views)
Please look my project.. it works but i need to do something to fix the VISA write, because this software do it:
read Line 1
VISA write Line 1
wait 1000ms
read Line 1
read Line 2
VISA write Line 1
VISA write Line 2
wait 1000ms
I need to send just new lines..
Did you understand my ideia ?
Message 4 of 9
(4,194 Views)
Hi Gorio,
I cannot open your LV2011 VI, so you might attach a downconverted version?
Message 5 of 9
(4,181 Views)
I sent LabView v9 and v10
Message 6 of 9
(4,171 Views)
Hi Gorio,
you always reload the full text file (or: you always start to read the text file at offset 0) because you use the file path for reading the file. If you would read the context help you would know that using a file reference would allow you to read the file line by line. There are surely examples supplied with LabVIEW that will show you the behaviour...
Message 7 of 9
(4,168 Views)
Insert something like this in your code.
Ben64
Message 8 of 9
(4,158 Views)
Thanks. It works. sorry my ignorance..
Message 9 of 9
(4,151 Views)
