Read from Absolute optical encoderHD25A with AT-232/4
We are trying to make a complete program to steer a test bench.
We shall simulate a torque using a disc brake that is steered by hydraulic
vents.
The encoder will give the position, and turns.
There will be no more than 20turns.
To measure the torque we use a torque-measuring ring, and after 20turns a
solenoid will stop the disc completely.
The card that I choose AT-232/4 may not be the best to use?
But 4 channels would be enough.
2 to read encoder and torque measuring disc
2 to steer the hydraulics for the brake and solenoid.
(2,494 Views)
Are you looking for LV examples for serial? you can find them in, C:\Program Files\National Instruments\LabVIEW\examples\instr.
Some useful resources for your application are
ni.com > NI Developer Zone > Development Library > Instrument Connectivity
http://search.ni.com/?col=alldocs&layout=TechResources&ql=a , to search examples and knowledge bases
(2,494 Views)
