Read from Binary File Doesn't work from SubVI
Okay, this is a first for me.  The Read from Binary File VI is only working when run from my base VI, and never when I place it in a SubVI.  It always returns error 1.  I've tried creating different SubVIs, and the error is the same.  The only VI that returns an error is the Read from Binary File VI.  The others will work from the SubVI.
I've included pictures because the VI has a ton of other project VIs, and the project is huge. I was also afraid that boxing up the portion of code for a dummy VI would warp the results of the problem I'm having.
This is LabView 2016.
This is the SubVI that does not work.This is the SubVI that does not work.This is my probe results for the SubVIThis is my probe results for the SubVIThis code works perfectly fine even though it's just a copy-paste from the SubVIThis code works perfectly fine even though it's just a copy-paste from the SubVIHere's the probe results when not run from the SubVIHere's the probe results when not run from the SubVI
Doe anyone have any clue what I could try from here?
Thanks.
Message 1 of 21
(5,089 Views)
What do you get if you probe the reference out of the Read Binary File?  I am just curious if the reference is still valid there since that is generally what causes error code 1.
Message 2 of 21
(5,078 Views)
EDIT: Apologies I misread the question and assumed it was the WRITE that wasn't working!
Message 3 of 21
(5,071 Views)
The reference is the same and still valid.  I can delete the error, and nothing else causes any error with that same reference.
Basically, using the same reference, the next write does not create an error, and the read does again (only in the SubVI).  It's very strange.
Message 4 of 21
(5,057 Views)
In your image for "in the top level version" the error cluster is not wired. Could it be that it does have an error but because the wire is not wired you are suppressing the error?
If so it may come down to the file not existing on an initial go?
No answers here, only questions,
Ben
Message 5 of 21
(5,038 Views)
Ben
Sorry, I made that a little confusing, but that case only runs when there is an error because if there is no error, the array will not be empty.  In any case, if the Read VI were causing an error on the top level VI, the second Read would be causing an error again like it does while in the SubVI.
Message 6 of 21
(5,033 Views)
Is it possible the file is being created in a parallel thread and not there yet?
And as a shot in the dark, can you toss the while loop since it does not do anything anyway?
Ben
Message 7 of 21
(5,027 Views)
Then the error would be coming from the Open/Create/Replace File function.  My similar follow on thought was a parallel process deletes the file before the read.  Seems very unlikely, but that is all I can currently think of.
Message 8 of 21
(5,023 Views)
I am not good at troubleshooting images, but if you take the working version, lasso the relevant code, and "create subVI from selection", do you still get the same error?
Message 9 of 21
(5,016 Views)
Ben
I'm not sure what you mean by the first part, but I tried the second part, and the problem still exists.
Message 10 of 21
(4,991 Views)
