Read from NI Distributed System Manager
Hello all
 I need help in how to read data from  NI Distributed System Manager to LABVIEW (real time)
Think you
Forza Juventus
(4,227 Views)
Can you talk a little about the hardware you're working with? If so, I can help you find some good examples to get you started with it in LabVIEW RT.
(4,160 Views)
Hello
 Compact RIO cRIO-9149
Thinks
Forza Juventus
(4,149 Views)
Looks like you're trying to read some values from a module in your cRIO, and this document should help you get started with a basic application using the cRIO Scan Interface.
Getting Started with CompactRIO - Performing Basic Control:  https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0UdCAI&l=en-US
The CompactRIO Developer's Guide can help explain concepts when getting started as well: https://www.ni.com/en/shop/compactrio/compactrio-developers-guide.html
Additionally, in LabVIEW, you'll be able to go to Help > Find Examples > Browse > Hardware Input and Output > CompactRIO > Module Specific IO and find some example projects with some of the modules you have.
(4,133 Views)
