Read from Spreadsheet File.vi reading from a specific row
hi everyone,
I am using Read from Spreasheet File.vi to read csv files.
I want to start reading the data from the 4th row everytime (there are useless headers in the first 3 rows). But the "start of read offset" lets me count characters instead of number of rows. My files have random number of characters before the 4th row so there is no way i can use this function.
Is there any other way to read everything starting from the 4th row?
Thanks all,
Tai
Message 1 of 12
(10,112 Views)
Hi BestPker,
I would suggest you read all the data first and then modify the "raw" data using the Array Subset VI from the array palette.
I have attached a very simple VI that will do what you want, as well as a spreadsheet of some random data.
Anthony Wong
University of Toronto
Chemistry Department
Message 2 of 12
(10,109 Views)
That certainly works. Thank you! Smiley WinkI still hope there are other ways.
Message 3 of 12
(10,104 Views)
Is there any way you guys can upload a picture of the vi
Message 4 of 12
(9,172 Views)
You need to ask more loudly.  Neither of those persons have logged into the Forums since 2007.
This is basically what you are being told in your thread.
Lynn
Message 5 of 12
(9,154 Views)
Yikes.  That's quite the zombie thread bump.
Really, what part of the advice would you benefit from seeing a picture?
They gave two steps:
1) read the entire file
2) get rid of what you don't need
The first results in an array.  The second can easily be handled with an array subset function.  What picture will help there?
Message 6 of 12
(9,144 Views)
Figured out a way that would work for me,
Thanks guys!
Message 7 of 12
(9,108 Views)
Does anyone know the name of the VIs they are using? I've got the same issue... I have a .csv and i want to start reading information at line 16.
Message 8 of 12
(7,276 Views)
Read text file, Match Regular Expression, Spreadsheet String To Array, Transpose 2D Array.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 12
(7,270 Views)
Thank you. "Unfortunately"/Fortunately I had just figured it out and hadn't gotten back to clarifying it here. I'd just like to point out to anyone that you can only use Match Regular Expression "R50" in the picture if you know what the Header ends with in this particular case. The individual was searching for R50, which is how their header terminates.
Message 10 of 12
(7,267 Views)
