Read from changing PNG File
Hello everyone,
I wrote a python program that plots a graph and saves the figure every five seconds. My LabView VI can Access this png file if the python program is not running. If however the python program is overwriting the existing Image to save a newer Version of the figure, the Read from PNG VI gives out an error and the VI stops.
I think it is because the Read from PNG.vi is reading the png constantly and when it is overwritten by python the file the vi was reading is gone.
Any help with this?
Can I somehow Close the handle to the png in labview?
Thanks for help!
(2,901 Views)
Accepted by topic author EnzoC
Hi Enzo,
implement some simple error handling!
WHILE
  ReadPNG(png-file)
  IF error THEN Python script is working; Wait 500ms
WEND
You might also check the file timestamp and only read the file when it has changed.
(2,894 Views)
