Read from channels
What is the advantage of reading 25 samples each from 6 channels 10 times to get a 6x250 array , instead of reading directly 250 samples per channel to get 6x250 array of data? Sampling rate is 1000.
Message 1 of 28
(5,241 Views)
It depends on the type of signal you read. What is the actual requirement? What is the 1000 sampling rate when you are trying to read 250 samples? 250 samples/second? Please explain
Message 2 of 28
(5,231 Views)
Difference is mostly how fast a graph will update.
P
The number of requested samples does not change the sample rate.
Message 3 of 28
(5,223 Views)
Okay
Does using "daqmx read" 10 times in one frame read the same 25 samples 10 times ( i.e again and again)?
Message 4 of 28
(5,214 Views)
P
Yes it is true when you read the channel with Multiple samples. But When I read the channel 1 single value (1 sample on demand) on every iteration of the loop (Lets say my loop runs at 100 Hz), then what determines my sampling rate?. I am trying to understand, please advice.
Message 5 of 28
(5,211 Views)
No, each time the read is called, you get new samples.
Message 6 of 28
(5,207 Views)
So can that be called a 100 Hz sampling rate? Or any other technical term to denote that?
Message 7 of 28
(5,200 Views)
Because of jitter, I'd say you have an unknown sample rate.
Message 8 of 28
(5,195 Views)
Dennis,
Okay.
Which method updates the graph fast? Reading 25 samples(new samples each time) 10 times or directly reading 250 samples?
Both take 0.25 seconds( if sampling rate is 1000) right?
Message 9 of 28
(5,183 Views)
Yes, I agree with this.
Message 10 of 28
(5,181 Views)
