Read from database line by line
For a project work at school I need to make a VI which reads text from a database.
I'm currently able to read from it and save it all at once in an array.
But the task is to read the database line by line, depending on a random number which I generate.
This random number will be the number of the row in the database in microsoft access.
Does anyone know how to do this? Or better, have a VI which does what I want?
Thank you in advance.
(3,107 Views)
Hello!
Can you share the code you are using now?
(3,081 Views)
This VI reads the database all at once and writes all the lines immediately into an array
(3,065 Views)
