Read from parallel port
I know it's possible to write some data to the parallel port using
LabVIEW, but I don'y know if it's possible to read from the parallel
port.
If someone knows, please advice.
Thanx for reading.
Paul
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,760 Views)
paulhogan@my-deja.com wrote:
>I know it's possible to write some data to the parallel port using LabVIEW,
but I don't know if it's possible to read from the parallel port. If someone
Thanx for reading.
Paul
Yes, it is very easy to read from the parallel port. There have even been
some VIs floating around allowing you to use the parallel port for digital
I/O using the inport and outport VIs.
To just use it to communicate, just use the VISA VIs with the proper resource
name for the port you are using.
(3,760 Views)
If someone has an example, i'll appreciate it.
Thanxs
Paul
In article <38467e4f@newsgroups.ni.com>,
LabVIEW,
someone
> Thanx for reading.
> Paul
been
digital
resource
Before you buy.
(3,760 Views)
