Read from text file by line
Thank you all for a reply.
It looks like I need to add an open text file, a stop condition for when it gets to N+1 iterations, and a new conversion from string to integer.
Message 11 of 12
(618 Views)
Hello Josh_Music
You do not have any "for loop" as you are mentioning.
Try to search this example and understand how the "Read from text file" works.
It could be that a better way to develop your code emerges.
Open LabVIEW > Help > Find Examples > Search tab > Type the word "write" on it and select the shown example below.
In addition, you can also debug your code and see what is happening with this part.
Staff Technical Support Engineer
Message 12 of 12
(607 Views)
