Read input then compare and turn on LED
I have very little experience at writing in LabVIEW and am stuck on some basics. I was watching this video tutorial http://www.ni.com/white-paper/5370/en/ on building an analog input and all worked well. I was using a USB-6229 BNC and had a very slow varying voltage (0 to 5V) applied to Ai0.
I then wanted to to compare the varying input to a 2.5V level and then turn on a LED connected in series with a resistor to the digital output P0.0 if the input went above 2.5V and turn it off below 2.5V. It is this bit that I am stuck on. Can you help please? Once I've done a few of these exercises and find my way around, then I'll be on my way. It's just an initial bit of help needed. We've all got to start somewhere.
(2,870 Views)
Hi Mike,
Can you attach your code or take a snap ?
so that we can have a good idea were you went wrong?
Boldness has genius, power and magic in it!'
(2,856 Views)
I've attached an image of the block diagram. There isn't much added from the original NI example because I really didn't know where to begin.
(2,851 Views)
Hi Mike,
don't read a waveform from DAQmxRead, instead set it to "1Chan 1Sample". Then you receive a scalar value to perform your comparison on!
(2,846 Views)
Hi GerdW,
thanks for your reply, but I dont really understand. As I said, my knowledge is very limited to non existent. I've got an analog input which feeds into a 'greater than or equal to' function along with a 2.5V set point. I just want to toggle a LED on p0.0 when the threshold is crossed. Any chance you could just show me this in the block diagram please? I will then undersatnd what to do and move on from there. It must be one of the simplest things to do if you know where to start.
Mike
(2,835 Views)
