Read only limited samples from the continuously coming samples
Hi..
I am using the NI DAQ PCI CARD 6534 for my digital data acquisition application. I Am using the DAQmx drivers for this..
I am taking the coming samples contentiously from my circuit but I want to update my graph after every second.So my application is to read the no of samples the system can read in Sec and then update the graph..
I have tried a lot for this but as its continuous acquisition the system reads all the available counts in the buffer memory.. So can anyone help me for this so I can read only the samples which the system can read in second.
I have set the read property position to current position so it will give me the starting point for the read but how can I stop the reading the after one second..
Please some one help me its really urgent and important for my further application.
(2,213 Views)
If you want to continuously update, you better use chart and restrict loop iteration to one per second using 'wait until next ms multiple'.
Pradeep.
(2,205 Views)
