Read out from Labview when CANoe start-procedure is finished
I use Labview to start my CANoe program (the software and the configuration is already open). To shorten the time to continuo with the next SubVI (actually I am waiting for 3s), I want to get a feedback from CANoe when the simulation is running (CAPL-programs pass their Start-area, ...). Is there an ActiveX control with a property node/invoke node to read out this status?
(2,735 Views)
Hi Michael,
If I understand correctly, you want to read the CANoe status in LabVIEW with ActiveX.
You can use property/invoke nodes to communicate with registered ActiveX servers. Does CANoe provide an ActiveX interface?
Here is some information on using ActiveX in LabVIEW:
http://zone.ni.com/devzone/cda/tut/p/id/10060#toc4
Also please lookup ActiveX in the LabVIEW example finder.
(2,723 Views)
