Read several analog inputs at the same time?
I am using the labview 7.1 and the example "Acq&Graph Voltage-Int Clk.vi " to aquire date. How ever, I need to read 7 channels at the same time and this example doesn't seem to enable this ( only one at a time ). Does anyone know any example that could soot my application ?
(I nead to acquire data in real time and then right the data into a file every sec or half a second but that's ok)
I would appreciate any help,
Thanks a lot,
Marc
(2,521 Views)
When you click the selection arrow in 'Physical Channel' go to Browse
This will bring up a list of all possible channel to select from.
While selecting, hold down the 'CTRL' button and you will be allowed to select more than one.
Randall Pursley
(2,507 Views)
