Read tach signal using DIO to measure rpm
I have a brushless motor with a pulsed tach-out signal (2 pulses per revolution).  I will be running 5 of these on test and desire to read the speed at regular intervals during the test.  I only have one counter available but in conversation with a consultant, was told I may be able to read the tach signal with a DIO channel.
I am operating with a PCI-6221 card with an SCC-68 right now. (The other counter I am using to control the digital PWM input on the motors as I can use one counter for all 5 motors)
If anyone is aware of a method to accomplish this, I would very much appreciate some assistance. This type of programming is a couple levels above my current capabilties.
Thanks....    Doug
Doug
"My only wish is that I am capable of learning each and every day until my last breath."
(5,912 Views)
I would recommend trying to do the measurements you want in MAX first -- then you know more about how you want to do it.
In LabVIEW, it would be a matter of either using a loop to get a set  of data (say 1 seconds worth -- set up with the DAQmx functions), counting the number of pulses, and then figuring out the speed.  So, which part(s) do you need help with:
1) DAQmx setup
2) The loop
3) Retrieving DAQmx data
4) Counting pulses
5) Figuring out speed
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(5,897 Views)
[I would recommend trying to do the measurements you want in MAX first -- then you know more about how you want to do it.]
I am actually doing that.  I have one task using /port0/line4 on dev6221 and configured with continuous signals. I don't know if this will work or not but the problem is figuring out what type of clock settings to use.
A second task I am working with uses /ctr1 set to "rising edge" and "1 counter" method.  I obtain a measured value with this method but it doesn't equate to the actual speed of the motor.  I am using an LED strobe to verify true motor speed.  I am also not sure how to verify what counter timebase rate is being used.
Thanks...   Doug
Doug
(5,890 Views)
Hi Doug,
Did you able to solve your problem? I have the similar kind of problem of measuring RPM data from encoder. I only get single RPM value not continuously. We can also discuss about it if you want.
Thanks, Zia
(5,840 Views)
Hi Zia,
While I am able now to obtain a tach reading using one of the counters on the DAQ device, I still have not been successful using just the DIO.
This is the code using the counter.  The Task uses a Counter channel for Frquency.   I set it for 1 sample on demand, Rising edge and 1 Counter measurement method.  It took a little trial and error for the multiplier to get the actual speed as it wasn't obvious what daqmx was using for internal timebase.  If needed, I can post a screen capture of that set-up as well.  This vi needs to run continuous.  I used a meter on the front panel with the additional numerical readout to give it a little jazz.
I have not been successful using a DIO yet and am still working that off and on.  I would like to be able to have five independent tach inputs for running multiple units on a life test. I will be trying some more next week and if/when I am succesful, I will certainly post.  If you have any ideas, I am open to try different things.
Thanks....    Doug
Doug
(5,827 Views)
Hi Doug,
I am using laser tacho with 60 pulse disk and inputting it into PXI 4472B analog channel. I will try your NI for my purpose. Can you send LabVIEW NI of it?
I tried analog Tacho processing sub-pallette, but getting wrong speed profile. How did you set tacho into your motor? What type of tacho are you using? Waiting for your reply. Thanks.
Regards, Zia
yahoo
(5,820 Views)
Hey Kudos
Do You know how to make a counter with Labview, I am struggling. I know the post is from 2009 but I hope you have a solution for it.
(3,572 Views)
