Read udp
Sorry, sorry, the value of the string is "signal (1.0) 125458" (and the value at that point in time)
  It is a communication with BCI2000 and I can not modify the data you send me the program, I'm trying to make a connection in real time.
For processing these signals.
Message 11 of 22
(3,144 Views)
Then you need to parse out the string.  If it is empty, do nothing.  If it is each of the other things, then you put the value in the appropriate chart.  One parse, one case structure.  Not multiple parallel things.
Message 12 of 22
(3,135 Views)
You could make me an example or something indicative, please
Message 13 of 22
(3,129 Views)
can you explain exactly what you wanted to do?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 14 of 22
(3,125 Views)
I want the signal behaves as a zero-order hold, that those gaps that these gaps are zeros values ​​have
Message 15 of 22
(3,115 Views)
Sorry not able to get information on what to do.
Just tell whats your input and how your output wanted to be in clear way.
In other way input value and the expedted output value.
Message 16 of 22
(3,112 Views)
I want to separate the three signals separately since they are three different channels and what I represent in the accompanying photo.
This is what I need
Thanks!
Message 17 of 22
(3,107 Views)
Hello solved the problem in a photo, I did not need anything UDP change anything.
Thank you very much for your interest 🙂
Message 18 of 22
(3,100 Views)
With the help of a teacher it has improved the previous solution and no longer have any problem with reading because I run the selection only when the string is not empty.
The solution is the photo.
Thanks!!
Message 19 of 22
(3,093 Views)
I have a question, in the time loop frecuenca can choose the refresh, but in the while loop that runs frequently?
Message 20 of 22
(3,073 Views)
