Read varying data length
I am looking to use a TCP connection but I have been unable to successfully reproduce a 'bytes at port' reader for the TCP line before a Read function.
(1,865 Views)
Conventionally, the sender send 4 bytes first, indicating the size of the following message. Else just keep reading and parse as needed.
Do you have control over the sender code?
(1,862 Views)
I know that the data i am reading comes in the format * 0,0,0,0 (minimum length) or * -10000,-10000,-10000,-10000 (maximum length)
(1,848 Views)
Does the message end with a Carriage Return and/or a Line Feed?  If it ends with the CR LF, you can set the TCP Read to use CRLF mode and it will then read up to that byte combination.
(1,822 Views)
