Reading 1-wire DS18B20 via a serial with USB adapter
Hi
I have been trying to monitor temperature with two DS18B20 and DS9097 connected to computer via "Y-105 UST To Serial Adapter". I tried to use https://decibel.ni.com/content/docs/DOC-1092.  But when I run NI: Reading several 1-wire probes via serial or USB adaptor in LabView 2011 I  get error Memory is Full. I installed Maxim's SDK and replaced all .dll, but it didn't help.
When I run Start Session.vi I get Handler, PortType and Port Nb correctly.
What should I do now?
(3,761 Views)
There is an exe (lbview32.exe) in the zip. Have you tried it? Is your device working properly?
Could you wire the error inputs and outputs (like on the attachment)? What can you see on the error output?
Peter Vago
(3,727 Views)
