02-17-2016
02:46 PM
- last edited on
08-25-2026
06:08 PM
by
Content Cleaner
Hello, I have what I think should be a really easy application to build, but I have some questions about the approach I should follow.
I have an ASI IO SV DIO 4/3 AB to which I want to be able to configure it's address, read digital input status and write status to digital outputs.
This device uses AS-i network to comunicate to an AS-i Master which at the same time has a PROFIBUS port to communicate with a PROFIBUS Master.
I am completely new to working with AS-i and PROFIBUS, and I have been looking around for a way to communicate to the AS-i device from a PC.
Right now, I have an AS-i 3.0 PROFIBUS Gateway (similar) as a Master for the ASI IO, and of course I am able to see the digital IN status and write to the digital OUTs, but all this is done manually through the front panel.
I've looking around for a solution, and I've found a PCI card from COMSOFT that it's supposed to have the ability to communicate to PROFIBUS slaves, though it sounds great for my application, I don't fully understand it's functionality.
Can I use it as a real time master, let's say, to be able to read those DIs and write to the DOs in the AS-i device, from LabVIEW code?
02-17-2016
05:08 PM
- last edited on
08-25-2026
06:09 PM
by
Content Cleaner
PCI Profibus card will allow LabVIEW to "act" as either Profibus Master or Slave depending how you set it up. You will be able to read and write profibus channels/ IOs via LabVIEW.
I'm not sure how your AS-I Profibus gateway works but I am assuming it is able to send or receive profibus commands and interpret them into AS-i protocol. If that’s the case then you will use Profibus card to send whatever command is necessary for your gateway to "translate" it into an AS-i protocol. You should refer to your gateway manual if that is the case.
Just FYI, NI does sell AS-i master which means you can skip whole profibus conversion and do AS-I protocol directly in LabVIEW. However, this module only works with compactRIO platform so you will have to get cRIO in order to use it.
