Reading ATML with LabVIEW
I have inherited 200+ TestStand generated ATML results files.  I need to combine the test measurements from each file into a single Excel Spreadsheet, ideally using LabVIEW.  I have no experience of crunching XML or ATML in LabVIEW and currently cannot even open the files in a useable format.  If anyone has done this sort of thing before or knows how to do it and can provide me with a starting point (or two) it would be appreciated?
Steve
(3,261 Views)
Hi Steve,
You can read ATML files in DIAdem with the data plug in available: https://www.ni.com/en/support/downloads/dataplugins/download.ieee-standard-1671-dataplugin-for-atml....
Kind regards,
Kelly
(3,209 Views)
Hi Kelly
Thanks for the reply.  I have not had much exposure to DIAdem, but did read on ni.com that people had imported TestStand results into it.
It doesn't help me though as I do not have access to DIAdem.
Regards
Steve
(3,200 Views)
