Reading Comparing Writing to Com Port Memory
I have an old basic program that writes, reads, compares, and writes to COM port 2.
The Code has several for loops to create 76 bits of data to Self Clocking Differential +5V/-5V where A to B voltage is +5V =1 and -5V =0.   A & B both at +5V resepct to GND =Null.
The Code is written  as follows
For i=1 to 16
       If MID$(TOTALDIGITS$, 17-I< !) ="0" then
            OUT &H2FC, (&HFE AND INP(&H2FC))  'PIN 20 COM PORT 2 DTR
            For j=1 to Bottom: Next J   ' null time for bottom square wave
            OUT &H2FC, (&H1 OR INP(&H2FC)) 'PIN 20 COM PORT 2 DTR
else
           OUT &H2FC, (&HFD AND INP(&H2FC)) 'PIN 4 COM PORT 2 RTS
           OUT &H2FC, (&H2 OR INP(&H2FC)) 'PIN 4 COM PORT 2 RTS
          endif
     FOR  j=1 to TOP: Next J  ' Null time for top of square wave
Next i
For j=1 to worddelay: next j  ' Delay between words.
else where in the program  initalizes port RTS & DTR states
OUT &H2FC, (&HFE)
OUT &H2FC, (&H1)
OUT  &H2FC, (&HFD)
OUT &H2FC, (&H2)
Question
I saw several post about serial visa writes,   How would read the port memory for the DTR RTS pins and make the connection back
port write/read/data compare?   How does this compare to unasserted and asserted for the DTR adn RTS pins using property nodes?
Greg
Greg
(3,460 Views)
Here is my code to date
Greg
(3,456 Views)
I don't understand your question.
It looks like you've already found the property node for DTR and RTS.  There are also property nodes for CTS and DSR.  I don't know why you have a  For Loop of 16 iterations where on the first 14, it does one thing and the last two iterations it does something else.  You have no delay going on in there, so those iterations are going to run unbeleivably fast.
You don't have any VISA reads or writes in there.  It looks like you are just toggling the handshaking pins.  Is that what you want?  What are you really trying to do here?
(3,437 Views)
Thanks.  I was attempting to duplicate the basic program in the first post.
The program does not work.  I am getting 0000 on the display always.
The problem is the the 76 bit data string that gets made to talk to the serial display.
I have parsed out the 1000's, 100's. 10's, 1's Digit.   Now I need to develop  a conversion method to populate the 76 bit string show the appropriate Digiit and BCD segment is illuminated. See attached.
Greg
(3,432 Views)
