Reading DMA FIFO using Invoke method node
Hi
I am trying to read a DMA FIFO using invoke method node to read the data in the FIFO on RT.
It works fine but the problem is that it consumes a lot of CPU if the timeout is increased. Can
anyone tell why this is happening and if this is the desired behaviour then what other methods i can
use to avert this.
Please help at the earliest
Regards
Amit
(2,836 Views)
Hi
Can anybody help me as it is urgent ,
What i further found out is that is that it is eating up a lot of meory when continuosly polled up in a looop....
Regards
Amit Ahuja
(2,813 Views)
