Reading Data From text File
I would like to read data (numbers sepereated by spaces) and write them into an array. This is what i have so far.
Thanks.
Message 1 of 13
(7,581 Views)
Please explain how your textfile looks like (or post it).
It is possible that "Read from Spreadsheet File.vi" is sufficient for your task.....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 13
(7,577 Views)
This is the file I am currently testing the vi with.
Message 3 of 13
(7,570 Views)
Accepted by topic author wowden
Try using the "Read from Spreadsheet File.vi". The only thing you obviously have to change is the delimiting character, which seems to be a blank. In the default configuration, spreadsheet files use tabs as delimiters....
Norbert
Norbert
Expert: Geometry
Message 4 of 13
(7,559 Views)
i have a text file which contains hundreds of records... like given below... i want an application which can search the id and display the information
abcxxx123; name:john adress:abc123 weight:65kg phn-no:123123
abcxxx124; name:alpha adress:abc123 weight:63kg phn-no:123123
abcxxx125; name:bravo adress:abc123 weight:68kg phn-no:123123
abcxxx126; name:charlie adress:abc123 weight:67kg phn-no:123123
abcxxx127; name:mick adress:abc123 weight:67kg phn-no:123123
END
*************end of data*************************************
i want to retreive data from a text file like this one.. i want a labview application in which
when i enter the id..which is unique e.g... abcxxx123..it should search the id in the file and display all the other information
which is infront of this id... in a display text field..like for example
.... name:john adress:abc123 weight:65kg phn-no:123123 ...
please if anyone can help me in this regard...
Message 5 of 13
(6,990 Views)
You've posted into a 2 1/2 year old thread.  You really should start a new thread so that it gets the attention it deserves.  We have a few regex whizzes on the forums who I'm sure can help you figure out how to do it.
Message 6 of 13
(6,979 Views)
Ok...i dont know about this forum...i joined today..it ll take sometime to understand things..thanks for reply... please send me the link of the thread.. where i can find the solution..
Message 7 of 13
(6,976 Views)
Go to the main LabVIEW board.  http://forums.ni.com/t5/LabVIEW/bd-p/170
Click on the link that says "New Message".
Message 8 of 13
(6,965 Views)
Like this.
Ben64
Message 9 of 13
(6,954 Views)
@ben64 wrote:
Like this.
Ben64
I’m a super beginner and I can’t find the functions in your screenshot.
Can please you submit a VI?
Message 10 of 13
(6,556 Views)
