Reading Excel File Properties in LabVIEW
I have a large amount of excel data files I am reading into a labview program.  I want to use the date created property of the files to select only files in a date range.  How do I read this file property?
(3,776 Views)
Accepted by topic author spiff40k
It's dangerous to go alone! Take this.
Cheers
(3,770 Views)
Thank You! That helped.
(3,764 Views)
No problem! In general, you can get all of the information you need that you could normally get using Windows, you just have to use the Windows API.
Cheers
(3,758 Views)
