Reading GSD file from Siemens PLC in LabVIEW using Profinet.
I have to read GSD file from SIEMENS PLC S7 1500 in LabVIEW using PROFINET communication. I am struggling for this from long. Could you please suggest me which library we can use in LabVIEW for the same?
(2,026 Views)
Hello Vri,
the following document might be helpful for you.
<SINAMICS: PROFINET connection with LabVIEW>
https://support.industry.siemens.com/dl/files/399/99684399/att_1027263/v1/99684399_SINAMICS_LabView_...
FrankenChino
(2,012 Views)
Hiii Sir,
I have tried with SINAMICS. That is working. But that LabVIEW library is not useful to communicating with Siemens PLC.
(1,971 Views)
Hi Vri15,
could you be more specific about the issue?
You can also get technical support from Siemens direktly, just forward them the serie number of the product you purchased.
FrankenChino
(1,958 Views)
