Reading HTML files on the web
How can I read an HTML on the web and extract data from the HTML file into my VI. I am using SHDocVw.IWebBrowser2 activeX control to access the web page but I cannot figure out how to read the HTML into my VI. Is there an easy way to do this?
Jim
(6,453 Views)
Hi Jim,
one solution is to read the entire web page with datasocket.
Mike
Message Edited by MikeS81 on 10-22-2008 08:38 AM
(6,432 Views)
"jimbo50" <x@no.email> wrote in message
news:1224625207538-796143@exchange.ni.com...
easy way to do this?&nbsp;Jim
Check out the www.mooregoodideas.com/googlabviewstuff.htm . The WinInet
library can download anything, from HTML pages to executables and single
images. Use WinInet Easy GetUrl to get a quick start.
Wiebe.
(6,423 Views)
Dear jimbo50,
There is also the URL Get HTTP Document VI, which retrieves a document specified by an http URL and stores it in a specified file or returns the contents as a string. You would then have to parse the string to retrieve the data that you required, and if the website formatting changes, it may break your text parsing code.
Best Regards,
~Nate
(6,412 Views)
Nate.H,
I was actually doing that to get some information from a website. I see that the way that I'm parsing the data (using Match Patternis) taking a while give me the result. I know that the original HTML document it quite big, but is there a quick and efficient way to parse this data?
Jose
(5,216 Views)
Hi Jose Perez,
First off, are you repeatedly searching the string for certain patterns, or just searching the string for the specified pattern once? If possible, your best bet may be to only search part of the string if you know that it will be in a consistent format, thereby eliminating large sections of the string. If you are searching in a cascading order (searching for one pattern that is always before the next ones), then you could split the string at the first pattern and only search the latter portion.
Also, you might want to consider making a new post since this thread is four years old.
Bill E. | Applications Engineer | National Instruments
(5,203 Views)
Ever Song,
Thanks. I'll be working on that.
Jose
(5,192 Views)
