Reading HTML files.
I want to retrieve text from a HTML document. I can isolate the body of the text in the document using the string match pattern vis. However I have not found a way to easily remove the embedded HTML elements for line breaks <BR> etc. Is there a way to do this?
(2,833 Views)
Use Search and Replace String or Search and Replace Pattern. Set Replace All to T and replace with an empty string.
You can try searching for VI which analyze HTML. The internet toolkit should probably have some.
___________________
Try to take over the world!
(2,830 Views)
