Reading More no.of files from Server by Internet
Hello all,
I need small information please help me.
Currently I’m reading bunch of files by using “Recursive.VI” and it’s working fine.
Now I want to know, if I want to read same files from Server through internet then how effects this VI.
Please let me know if there is any other possible solution to read the files from Server through Internet.
For your information, I want to read almost 2000 files.
Best Regards,
Guru
Munna
(3,019 Views)
Can you access these files from Windows Explorer?
You might be able to just supply the location to the List Files Recursive VI and it will find them using normal Windows file protocol.  It is like if you used a network drive.
(2,995 Views)
Dear Crossrulz,
Thank you so much for your reply.
I want to read Files from Network Server through Network(LAN). May be Recursive file VI will work just like Reading from Hard disc but haven't tried  this. Still I don’t have network access to my LabVIEW Development PC. I will check this after getting Network access. But just I want to confirm whether my approach is correct/not.
BR,
Munna
Munna
(2,988 Views)
To you, the network server is just a file location.  Windows takes care of all of the TCP/IP junk for you.  You just see a folder.  LabVIEW sees the same thing.  So yes, it should work.
(2,985 Views)
Yes. But may be it will takes more time for Reading this files (Depends On Network Speed).
Munna
(2,980 Views)
Correct.  And there is much you can do about that.  It would be slower and take longer even if you weren't using LabVIEW.
You'll just have to try things out and see how it works for you.
(2,978 Views)
