Reading Numeric Control Array Variable Names
Hello, this should be an easy question but I can't seem to figure it out.
I have an array of numeric controls.  I want to take this array and read out each numeric control variable name and then create a new array with all the numeric controls variable names.  Is there an easy way to do this with either a for loop with a property node or an invoke node?
Thanks so much!
Message 1 of 8
(4,801 Views)
Your question doesn't make sense. Each element of an array has the same name. Do you actually have a cluster, and not an array? Can you share code or a screenshot demonstrating what you have?
EDIT: Do you actually have an array of references to numeric controls, rather than array of numeric controls?
Message 2 of 8
(4,793 Views)
You're right I made a mistake in my original question.  What I am trying to do is create an array of the front panel control names that I select.  When I say name I mean the name the control was assigned by me.
What is the most efficient way of doing this?  Do I need to create a reference for each control?  I eventually want to use these names that are in the array and use them as my file headers.
Thanks!
Message 3 of 8
(4,785 Views)
Thanks!
Its in vi.lib the hidden gems toolkit puts it on a exposed functions pallete
Message 4 of 8
(4,773 Views)
Thanks Jeff.  Where can I find the "Find Obj By Label" sub VI?
Message 5 of 8
(4,756 Views)
With the help window.  There is a feature to show full paths and optional terminals.
That would be why I sent it as a snipet
Message 6 of 8
(4,750 Views)
That makes sense.  I was actually looking on how I can get the "hidden gems toolkit."
Message 7 of 8
(4,741 Views)
Tools>>Find LabVIEW Addons will launch the VIPM package finder
Message 8 of 8
(4,731 Views)
