Reading Real Time Data From each Excel cell individual
Hello
I just want to read data From Excel file made by user manually . Actually I am Preparing the excel from which I want to read the cell Depending on choice of user on Front Panel.
For More clarity Please Find Below attached picture of Excel.
Here if I select Current Rating then Tolerance Limit are set as per our Current Rating.
i.e if Current rating is
selected by user  is 0.5 then Upper Tolerance limit will be set to 5 and Lower Tolerance Limit to 2.5.
(1,056 Views)
Hi Tarunakgec,
and what is your problem/question?
  • Is this a real "Excel" file (XLS*) or a simple CSV file? (For LabVIEW starters I recommend to stick with CSV as you can use plain TextFile functions or Spreadsheet functions.)
  • Is the list of current limits fixed at edit time? Then you could use an enum in your frontpanel to allow the user to select…
Mind to share your VI? Keep in mind many people don't use the latest LabVIEW version, so downconvert to LV2021 or LV2019: File->Save for previous…
(1,052 Views)
THANKS !
(897 Views)
