02-12-2007 10:08 AM
02-20-2007 03:28 AM
Thanks for posting your query on the National Instruments discussion forums.
I’m hoping you can go to Measurement and Automation Explorer and do a file > export to save your MAX configuration to an .iak file that you can attach to this discussion forum so that I can take a closer look at the task that you have created in MAX. Would it also be possible for you to attach your VI to the discussion forum so that I can get a clearer picture of what you are attempting? Am I correct in assuming that you working with native low level NI DAQ VI’s or NI DAQmx VI’s on the block diagram? What DAQ card do you have in your machine?
I’m wondering if you have tried to create custom scales by right clicking on the Scales directory in the configuration tree in MAX (under historical data directory and above Software directory).
I look forward to your reply!
Kind Regards,
Kirtesh Mistry
National Instruments UK & Ireland.
