Reading XML from EasyXML
I'm trying to read attributes from XML File using EasyXML but while using it I'm not able to parse the attributes from it.
XML is something like this :
<image id="0" name="hello.jpg" width="1" height="2">
<polyline label="OK" occluded="0" points="4,5,6,7">
<attribute name="India">true</attribute>
<attribute name="Position">Best</attribute>
</polyline>
(1,959 Views)
Great.
Bill
CLD
(Mid-Level minion.)
(1,945 Views)
What have you tried so far?
Can you attach your VI so others can look at it to help debug?
-joeorbob
(1,911 Views)
Have you look at the Easy XML documentation? Right-click the Easy Parse XML vi and select "Help". At the bottom of the page the is a link to open the examples and in the first paragraph there is a link the the "JKI EasyXML" documentation, plenty of informations there.
Ben64
(1,875 Views)
