Reading a 2D txt file of binary data into a 2D array
So I have a text file of 16bit binary data, with 8 different rows and columns, so 64 total data points. I am trying to read all this data into a 2D array. My current VI is only reading the first column, and I can't seem to make it read each of the 8 columns. Can someone help me on this?
My current VI:
(4,053 Views)
Please attach the text file and your VI. Is the delimiter really a comma?
Is the data formatted in binary or is it a binary file? Big difference!
(We cannot see how things are connected from the picture. You don't need to wire the -1, because it's the default)
(4,044 Views)
The delimiter is really a comma. It is a text file that I wrote that corresponding to the bytes necessary to call specific DACs.
(4,031 Views)
Look on the File I/O Palette for Read Delimited Spreadsheet.  Note that the default delimiter is <tab>, but you can wire a comma (",") to this input and it should do "what you want".  Read its Help file ...
Bob Schor
(4,026 Views)
Accepted by topic author lmcohen2
Your wired delimiter is currently (in \-codes) "\t,", i.e. it contains an extra tab. make sure it only contains a comma!
(4,023 Views)
You're a life saver, altenbach. Thanks!
(4,016 Views)
