Reading a binary file
I'm trying to read a file which is in binary, and I've been uncessful, I get the following error message: Error 7 occurred at Open/Create/Replace File in TESTEXAMPLE.vi, and the possible reason is: LabVIEW:  File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.  Currently the program is in the same folder as the file I'm trying to read, so I'm not sure if I'm setting it up correctly.
Andrea
(6,859 Views)
Accepted by topic author AndreaD
Replace default data directory with application directory and build that path with the file name.  You can always probe the wire to see what the path actually is.
-Matt
(6,856 Views)
When called from the VI, "Application directory" will be Labview folder, If it is executable, then it is folder of executable, not always convenient. Also Windows approach is that Program Files folder should have restricted access and not to be used for user data.
I prefer to use folders relative to windows constants: File functions -> File Constants -> Get System directory, then User desktop, User documents or other location for data.
Default LabVIEW data folder is Current User Documents\LabVIEW data, or can be changed in Tools -> Options -> Paths to something fixed.
(6,842 Views)
If you are using a project, like you should be for everything now, then the Application Directory returns the folder of the project file.  This is when it is extremely useful (bouncing between Project and Executable).
(6,828 Views)
If you actually have the file somewhere and you are just trying to test things out, the simplest, fastest, most-error-free way to use Open/Create is to wire a constant to the Input.  Now, right-click the Constant, choose "Browse for Path", and navigate to your file.  Now you'll open exactly that specific file.
Bob Schor
(6,813 Views)
Project - yes and always.
Application directory function - yes, path to project location. Application directory property - path to LabVIEW. Anyway you need to distinguish between exe and vi.
(6,799 Views)
Alexander_Sobolev wrote: Application directory property - path to LabVIEW.
I have never seen anybody actually try to use that in actual code for this purpose.  But it does make since when in the dev environment since the application you are running is technically LabVIEW.exe.  The Application Directory function knows better and will return the project's folder if there is one.
Alexander_Sobolev wrote:  Anyway you need to distinguish between exe and vi.
No need to distinguish when using the Application Directory function.  In in an executable, it returns the folder of the exe.  If you have your directory structures set up half way intelligently, then the relative paths between your files and the project file should match that of the files and the executable.  Therefore, you do not have to worry about which environment you are in.
(6,790 Views)
