Option 1 (easiest and probably best)
- Download the file from the Windows system to the RT PXI controller using FTP.
- Read the file locally on the RT system.
Option 2 (more flexible for your application, but more work to implement)
- Write a small communication VI that will run on your Windows machine that will accept a request over Ethernet to send a file to the RT system. This VI will read the file on the Windows machine and send its content using TCP/IP functions to a VI on the RT system, which will store the contents back into a file on the PXI harddrive.
Christian L
authored byChristian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
