Reading a spreadsheet file with the Read assistant - File Close Issue
I'm using the assistant to read a comma delimited spreadsheet file but it won't close the file when it is done, unless I close/stop the VI.  If I don't use the assistant the file closes fine.  I need to do this in order to open the file (not as read-only)  for other programs while the VI is running.
(3,981 Views)
Sorry, I am unclear what you mean by "assitant". Are you talking about the express VI?
In any case, reading a comma delimited file is pretty simple, just use the plain file I/O finctions and set the access options as desired.
(3,969 Views)
Thanks for the reply.  Yes, the assistant.  I'm just learning so I'm not sure how to easily use the read from spreadsheet file to create a waveform (first column is time, no headers).  The options with the assistant were perect for this.  Can I change this to the file read command without too much work?
(3,966 Views)
Sorry, meant yes the Express VI.
(3,963 Views)
can you attach a datafile with a few lines?
(3,957 Views)
Here is an .XLS file with 16 channels and one time column (first column is time).
(3,953 Views)
Hello bsmyth,
       I recommend that you take a look at Reading Data from Excel File and Printing it on a Graph
Cheers,
NathanT
(3,931 Views)
