Reading comments from MS word
Is it possible to read the comments from a word document in labVIEW? How? Are there any limitations like size of word document etc.?
Message 1 of 9
(4,258 Views)
Yes it is. You'll need to use ActiveX.
I don't think there are any limitations to the document size.  As long as Word can open it, it should be okay.
RayR
Message 2 of 9
(4,247 Views)
Hi RayR,
Thanks for the reply.
Can you please post the sample code and commented document here? Which ActiveX do I need to access in LabVIEW program.
Thanks in advance!
Message 3 of 9
(4,240 Views)
It would take me a bit of time to prepare an example.  Maybe during lunch..
In the meantime, have a look at this thread to give you some idea of what the code looks like:
And this link has an example at how to open a Word document..  There's also another example further in the thread.
That should be a start.   You can also do a search on Word and Labview.
RayR
Message 4 of 9
(4,230 Views)
Thanks RayR!
I'll go through these links........
Message 5 of 9
(4,217 Views)
I am able to read the total counts of the comments / author / initials but not the actual contents of the comments. Could any one help me from this point onwards. Attaching the code here- (Ver. 7.1)
Thanks !
Message 6 of 9
(4,171 Views)
Hi ITA,
this code is successfull:
I found this by just trying, the 'range' object can do a lot with the text, looks interesting.
Ton
PS. Is there a specific reason to zip your VI before uploading.
Message Edited by TonP on 07-02-2008 12:49 PM
My LabVIEW Ideas
Message 7 of 9
(4,156 Views)
Hi ITA,
can you upload a document, from which you want to read the data?
Mike
Message 8 of 9
(4,156 Views)
Hi TonP,
Thanks a lot!
Message 9 of 9
(4,129 Views)
