Reading data from datalog
I have a binary file that has time series data of 7 channels for separate 1s time stamps (number of time stamps=170); time is in the form of (t0 and delta_t). I would like to sequentially generate the fft of only channels 5 and 6. Hence, I guessed that the data could be treated as a cluster (x axis= channel number, y axis=time, z axis=time stamp). As a start, in Image_1,  I used 'datalog' and then 'index array' to read the first time stamp(Stage=1). Repeating the 'index array' option, I read the channels 5 and 6 (Stage=2) and was able to generate the ffts. However, on using the 'for loop' to move through 170 time stamps, I see an error when I try to connect 'datalog' to the 'index array' in the loop (labelled as 'First error' in Image_2). Hence, I was wondering if there is a better method to solve this problem. Any help is appreciated. Thank you.
(1,542 Views)
Just delete and rewire from the tunnel within the loop.
Unfortunately, I cannot edit images to debug.
Santhosh
Soliton Technologies
(1,526 Views)
Run your good Vi until "record(s) 2" contains data. Right click that indicator and change to constant. Delete the file IO. Save the VI under a new name and attach it here so we have something to play with.
(1,470 Views)
Thank you for the suggestion. Attached is the VI.
(1,399 Views)
