Reading files on a cRIO truncates them
I have problems reading files from the internal flash memory in an RT application (cRIO 9073).
Two files are read in a subvi just at the beginning of the program; if I run only the subvi, all seems to work well, but when I run the whole app, frequently I get errors.
Error codes may vary if I change the code someway (I tried storing files in different folder, using / instead of \, cycling read operation until no error, reading from the main vi and so on): in the past I got sometimes "File not found" (!), sometimes "End of file" (but the files where readable when downloaded to the development PC).
The current situation is that i get "End of file" AND the files are truncated to 0 bytes after the operation, although the ReadOnly access parameter (!).
Any hint?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,588 Views)
Please post your code as an attachment. Seeing your code will make it a lot easier for us to understand your problem.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(2,580 Views)
Uhm... I made a last attempt by flattening the datatypes to string and storing/reading them as text files. The program started to work.
Remark that the file content is the very same.
It keeps working even if I come back to the original code and delete the files.
Definitely I don't understand why this "solution" works.
Thank you anyway Thoric for your answer.
Paolo
(2,577 Views)
