Reading from PCIe-6346 analog inputs (without analysis, just save raw data)
Dear All,
we are planning to buy a PCIe-6346 daq card to read analog signals from several accelerometers. In the first round, there is no need to analyze the signals, just save the values as a row data from the eight channels. Would you please help me to find the easiest way to achieve that? I found that FlexLogger doesn't support this card, maybe an evaluation period would have been enough. Is there maybe any other NI product to save the channels data to files, which is free for a try? Or should I program it in LabVIEW (I don't have any special toolkit, so the professional version is available)?
Thank you for any hint!
Zsolt
(1,069 Views)
Actually, the best solution would be to use LabVIEW. You can easily write a small program to achieve that
(1,028 Views)
