Reading from a multi-segment measurement file
Thanks Kristen. I colud solve the problem by making it a single-segment TDMS file. The only problem that is left is that I have a "multi-column list box" which contents should be saved and loaoed as well. I tried to do this with the comment option by making the 2D string into a spreadsheet and passing it as a comment to the write function, but the read function does not recover the comment. What is your suggestion to solve this?
Thank you,
-- Reza
Message 11 of 16
(1,191 Views)
Hi Reza,
I'm not sure I follow.  Would you mind posting your code or a VI with this section of code that is giving you trouble? thanks!
Kristen H.
Message 12 of 16
(1,174 Views)
My main question is that how we can write a 2D array of strings to a TDMS file?
Message 13 of 16
(1,172 Views)
Hi rayt,
I was able to write stings to a TDMS file and read them too.  See below.
Kristen H.
Message 14 of 16
(1,154 Views)
Thank you Kristen. I'll try to use this approach mixed with Write/Read from Measurement file method that I have already used.
-- Reza
Message 15 of 16
(1,138 Views)
To keep everything in a single TDMS file, I used string to array functions and wrote them in the TDMS file.
-- Reza
Message 16 of 16
(1,119 Views)
