Reading .hpf file (LabVIEW 8.5)
I am trying to read an .hpf file and have LabVIEW 8.5 (from 2007). I wondering whether anyone has a vi (or libary ) that will read this file type? I am in the process of getting an updated copy of LabVIEW (so i can get the associated plug-in) but my colleagues and I are wanting to do some pilot analysis of some EMG signals relatively quickly (even if just to visualise the data initially).
Any assistance would be gratefully appreciated.
Message 1 of 11
(6,174 Views)
Hi Gus,
did you tried some converter like this?
Message 2 of 11
(6,173 Views)
Thanks for your post (GerdW). I guess we could do this (and that was put forward as an option in the meeting I had with the people I am working with) but we are ideally wanting to work with the raw .hpf file if humanly possible.
Message 3 of 11
(6,170 Views)
Hi Gus,
then you would need a complete detailed description of that file format.
Do you have such information?
Message 4 of 11
(6,168 Views)
Yep got it (See attached doc)... but quickly getting something together is highly desired in this case. I just finished another project working with a binary file format and it takes some time to write, then double check the routine etc etc. Hoe you see where I am coming from here. I am just trying to prevent re-inventing the wheel if possible.
Message 5 of 11
(6,164 Views)
I am thinking that the initial solution GerdW kindly forwarded  may have to be the way to go. These are useful URL's
http://www.delsys.com/knowledgecenter/nethelp/default.htm?turl=HTMLDocuments%2Fexamplematlabscript.h...
The question comes how to implement in LabVIEW. I found a vi from the site and then I get a little lost on what to put in the string to make in run under the dos environment (as per the Matlab sample). Anyone wiser than me on this?
Cheers,
Gus
Message 6 of 11
(6,135 Views)
Hi Gus,
in your link that DelSys FileConverter is called to create a CSV file.
Then you would use ReadSpreadsheetFile in LabVIEW to load that CSV file…
(No other matlab code needed!)
Message 7 of 11
(6,133 Views)
Hi GerdW,
Thanks for this. I will try it with a very large file and see how I go. If/when I get it working shall post the answer.
Cheers,
Gus
Message 8 of 11
(6,111 Views)
Thanks for all previous replies on this query - to close the loop on this problem, I got hold of a vi that will solve the problem and I have attached it. But I need it to be readable in LabVIEW 8.5 - can anyone help?
Cheers,
Gus
Message 9 of 11
(6,087 Views)
At the top of the page is a link to the Version Conversion board. That is where you need to post your VI.
Message 10 of 11
(6,049 Views)
