Reading in a binary file and displaying an array correctly
I am teaching myself Labview 7.1 and what I am trying to do is read in a text file of binary digits 10011001, 11011101 etc and then output these to a series of leds (boolean array) as well as to another array to display what was read in. I can get this to happen when I format the text file as 1,0,0,1,1,0,0,1 but then the array is 1 column by 8 rows (is this a 1by8 array) I want to read this data in as 10011001 displayed on 1 row and then the next row of the array to be 11011101, it displays 11111111 if I go above 3 digits, I know this is just a problem with binary versus decimal numbers, how can I format the input file so it is read in as 8-bit binary?
Thank you in advance,
Dan Ziehm
(2,941 Views)
If you use a function like Read From Spreadsheet File, use a format string of %b. By default, the function will return dbls but you can convert this to I32. For displaying binary on the front panel, right click on the indicator and select Format & Precision. Select Binary. You can also turn on minimum field width and choose to pad with zeros on the left. This is needed if you have a binary value of say 0111 and want it to display that way instead of just 111.
(2,931 Views)
Read the text file as string, then pass it through "spreadsheet string to array" with "," as delimiter, %b as format and an U8 array as type. I made a quick demo, see attached code image.
(2,928 Views)
thank you, I am working on reading the info in from the file I think I have got it I will post my code when it is done.
Thanks again,
Dan
(2,913 Views)
